twin air filters
whats your views on this ??? the filtters may not be any good but the pipework looks cool. the filters just bolt on so you could put your own on them. i rang the guy up about these and as a 1 off he will do a group buy if we wanted.
but as for the rules on here i dont know if i can sort out a group buy..
is there any trades on here who sell anything like this?? as i am thinking of buying it. £125 + £7.50 postage or he will sell 10+ for around £100 + postage
Poor design for flow. Would be better if the two came together in a Y shape. With that design, flow from each side has to turn through 90 degrees to get to the common piece and the flows will impinge on each other causing further restriction.
they have only made it like that because its easy to do, where like john said it would have been much better to make a Y shape but this involves alot more work and welding?
TBH looks a bit cheap and nasty and would have though a decent single filter like an apexi etc would have flowed as much if not more?
Sorry to put a downer on it ;)
wont a single filter do the same job anyway at the end of the day your only gonna get the same amount of air through the MAF.
or are you?
Bet you'd loose HP with that
cheers guys dont think i will get it now :bow: like i said look good but are they ???
If your a fairly competant welder you could make something A LOT better than that for around £50. I know im making a complete induction kit at uni at the moment and its costing me basically nothing in materials.
