Hey guys, I need to write a program based on the one below but I have no idea what it is doing or means, only 3 lectures into the course. Can someone who understands it make some notes next to each line for me explaining what's going on?
I don't know exactly what language it is but it's the one you write in DOS and then assemble and link, IBM PC i think its called? the module im studying is microprocessor programming.
Yas
[Edit: for some reason the tabbed lines stay to the left so i'v replaced the tabs with a dash]
.186
code SEGMENT para 'CODE'
ASSUME CS:code,DS:code,ES:nothing,SS:nothing
putdec:
-MOV AX,5
-CALL PUTIT
-MOV AX,4C00H
-INT 21H
PUTIT:
-PUSH AX
-PUSH BX
-PUSH CX
-PUSH DX
-PUSH BP
-PUSH DS
-PUSHF
-MOV DX,CS
-MOV DS,DX
-MOV BYTE PTR sign,00
-TEST AX,08000
-JZ POS
-MOV BYTE PTR sign,01
POS:
-NEG AX
-MOV CX,0000
-MOV BX,000Ah ;........................................ 10
again1:
-MOV DX,0000
-DIV BX ; .................................................divide by ten
-ADD DL,30h
-PUSH DX
-INC CX
-CMP AX,+00
-JNZ again1
-CMP byte ptr sign,00
-JZ plonk
-MOV AL,2Dh
-PUSH AX
-INC CX
plonk:
-MOV DX,6
-SUB DX,CX
newch:
-POP dx ; .................................................pop character
-MOV AH,2
-INT 21h
-LOOP newch
-POPF
-POP DS
-POP BP
-POP DX
-POP CX
-POP BX
-POP AX
-RET
sign db 0
allign db 0
CODE ENDS
End
those push, pop and move sound like stack operations to me, sorry I couldn't be more help- its been 4 years since i was at uni and I didn't even pay any attention when I was there
OK, I'm rusty as hell but I think it's x86 assembly language. Loads of info here including a decent tutorial http://grail.cba.csuohio.edu/~somos/asmx86.html. Thing about assembly is it looks horrible but each operation is actually really simple so you shouldn't have too much trouble figuring it out. In short
PUSH - pushes an item onto the stack and moves the stack pointer accordingly (depends on size of item: 32-bits, 64-bits etc).
POP - does the reverse of push: pulls an item from the stack and moves the stack pointer back.
MOV - moves an value into/out of a register
SUB/ADD/DIV - (integer) arithmetic operations
INC - increment
Like I say, once you've got a basic understanding it should be fairly easy to figure it out.
thanks guys, will be having a good look at it today. anyone else done assembly language before?
