Boost jets?
If i change the boost jets do i have to get my ECU chip or anything?
idealy yes,much safer if you do,not only will the chip more than often remove the limiter and up the rev limiter it will also or with some chips make the car run that little bit safer,so yes id get the ecu socketed
I don't think you 'have to' but I would for resons mentioned by Greg.
Speak to Andy P, and I believe others on here do them too.
doesnt the stock eprom only map fuel up to a certain boost level and having jets installed without an eprom upgrade mean there is a risk of running lean? or am i talking monkeys
