I can hear hear the relay inside the door clicking, does that mean it's working,
any ideas??
try changing black box which is behind door panel had same problem myself and after changing box window was fine
try taking it apart first they suffer generally from dry joints which mine had. a quick going over with a soldering iron on the joints and it should work again.
hth
gaz
hth
gaz
are you talking about the relay box, it looked like it was all one piece so i didnt bother trying to take it apart
you can take box apart but it will only cost £5 from Andyz etc
the black box inside the drivers door just clips together. my window stopped working in the summer when i went into a multistory carpark finally found a space while my gf got a ticket i put roofs on and went to do up window :headvswal so had to drive all the way home again 1hour later we were on out way back to the carpark :dance:
Sorted
Just one buggerin' joint that was disconected, made some contact with the solder and it works :dance: :duffer:
Sorted
told ya lol :x:
