Pc Help Needed
i have a problem with my pc :headvswal . it keeps restarting when it feels like it i get a error report thet says
0x0000000A(0x00000004,0x00000002,0x00000000,0x804E6617)
i've tried everything even reinstalling windows xp 3 times still the same thing.
is there a program that wipes the hard drive totally to make sure nothing is still on it.
could be memory fault m8
just format the drive when u reinstall XP
i have done that still the same
saying that i have had i reply about some thing might have overheated i heep getting differant errors i say about overheating onr something about the ram and one about driver problems but it cant say which
would this happen if i put two differant makes of memory in this is the only thing i can think of i have had this problem for about 8 months and i've had it i'm going to hit the bloody thing
What mother board have you got mate. I had similar probs. Memory was ok fan was spinning it was doing my head in. I bought a new MB and its been fine ever since. Mind you I had to re-install Xp again.
Sounds possible that a fan has broken. Power it up with the lid off and see whether they all spin up.
just took the back off all fans are ok. i looked at the ram and they are two types one is samsung which came with it and one is infineon which i put in. i have taken it out to see if its that
If your motherboard has voltage adjustment facilities in the BIOS try bumping the DRAM voltage a notch or two, some need more than the JEDEC standard of 2.5v
It must be RAM. If i am not mistaken you cannot use two different RAMS from two different manufacturers. You will get frequent errors
You can use it but it will error. try the link I put in, it will test your RAM for you....
Try it with just one stick of RAM, then try it with the other.
Could be a duff stick or incompatibility problems.
Using two types is a bad idea though!
thanks for the replies
i done the memory test and it passed.
i spent £70 on a new hard drive reinstalled windows with minimum drivers needed and still the same :headvswal
can a pc wiz with ten minutes free let me speak to them on the phone as typing the syptoms is quite hard to do
07899884953 or pm me your number and i'll call you
i have put asus probe in my pc
when i look at the monitor it says the following
temp 32-41 says ok
+3.3v is 4.08v it flashes +3.3v out of threshold
+5v is 6.85v and this flashes out of threshold aswell
+12v is 16.32V this also fashes out of threshold
does this mean anything is the voltage to high
