just a quicky i need to replace my rear wheel studs can these be done by just removing caliper and disc then knock them out or does the hub have to be removed? many thanks kev
Yep just take off the bits you have mentioned but dont forget that the studs are different on back and have a different part number do a search as i recently put the part numbers for front/back on a post
As you said caliper and disc off knock out studs and refit new, , take the opportunity whilst your in there to clean up the handbrake shoes and assembly and this will improve the efficency of the handbrake and lower the lever position.
Jeff TT
