protoj ·
well had a bit of a rumble on the car when coming back from the meet sunday.. went to my mates tyre shop today, took wheels off and well..
front left 50 out on balance
right front 30 out
rear left 30 out
rear right 5 out
no wonder it fookin rumbled!!! much better now!! back in week to check em over again.
you were right again baggins matey!! thats a drink or two i owe you!!!
