Boost jets
At the moment I have 1.2mm fitted and I'm wanting to "test" 1.0mm. Would it be ok to leave the 1.2mm in and fit 1.0mm in an extended pipe or should I remove the 1.2mm and just fit the 1.0mm ?
CheerZ
Paul
take the 1.2 put and fit the 1mm i'm running 1mm jets and hitting 14.5 psi boost
Are you running all stock parts i.e. tubs, injectors etc, do you get any det at all ?
CheerZ
Paul
ive got 0.8mm jets and after market boost gauge is showing 16psi is this safe ?? on stock turbo's with usual induction catback exhaust and ud pulley
there are slightly varying opinions of this, but in general as long as your tubbies are in good nick and you look after your car, 15psi should be fine (some run 16psi :eek: ) on standard tubbies, interns, etc.
i ran 15-ish on my 1mm jets before the blitz controller went in :bow:
CheerZ
Paul
no probs at all with mine running all stock tubs etc and got one of chris c's chips fitted
