Power feed for Amp??
I have taken battery out to see if I can find a suitable hole to feed the power wire for the Amp through and nothing really jumps out at me as being suitable, I have done a forum search and there is supposed to be a hole through the bulk head near the bottom?? I can see some sort of pipe with a big grommet going in, but I do'nt really want to disturb that. I am also worried if I drill a new hole through I will drill through a electrical wire going to the ECU, any pictures of what other people have done will be great. CheerZ.
Feed them through the gromet that the Bonnet release cable goes through. Drivers footwell, follow the cable from the bonnet release handle until you see where it goes through bulkhead. Feed cable through there till you see it appearing in engine bay.
Just had a look mate as its all incased in a plastic sleeve and it appears about half way down above the front wheel, so in order to feed it through and be able to see it I think I might need to remove the front drivers side wheel arch liner, I also hope my amp cable is long enough.LOL
an alternative is to feed through the plastic cover that feeds into the passenger wheel arch, its to the right of the battery. you can then feed through the grommet that feeds the door electrics into the passenger footwell and along the sill to the boot. hth
