300 kph
:hyper: now either i have a very quick car showing over 300kph or my speedo is fooked as not on full boost and only doing 2800 rpm :rant: damn more pocket money req must ask the wife for a raise :headvswal
try resoldering the joint behing the speedo as they can suffer from dry ones causing problems.
don't condem it yet.if you are not confident in doing it some people on here eg andyp can probably assist you for a small fee .
hth
gaz
I have this, every now and then, the speedo just goes all the way round to off the clock. I have to bang the top of the speedo cluster hard to get it to go back or switch the engine on and off.
Could it be something to do with the jap to uk speedo convertors (most likely)or is it more to do with the speedo and its connection itself ?
Olly.
Buy yourself a Sat Nav and use that for a speedo. Its more accurate anyway. :rofl:
Time to do a 0-300km/h run ;)
__________________
:hyper: quicker than urs does 0- 60 approx 6 feet distance :hyper:
:bow: even does 300 kph in reverse foook me thats very scary :rofl:
__________________
Is there a parrot in here? :tongue:
EDIT - why has it quotes zxally's sig??? :confused:
EDIT - i am a plonker
