Turbo timer change
I have what looks like a dated blitz tubby timer, can i buy a new one and just unplug the old one from the connector a little way behind the unit, and then just connect a new, or do they have to all be rewired in??
cheers in advance
Mike
From what i have been told all the turbo timer harnesses are the same HKS GREDDY BLITZ APEXI etc .If you are fitting a more modern timer this should plug into the old loom but you may need to run extra wires to the ecu for the full auto operation of the eg rev sensor .And also the handbrake switch wire .
Hehe, I'm like jealous as fook SERIOUSLY,
but gonna take your advice as of phone call last evening and get her back together
asap, just lookin for air ratchets and gotta get the old compressor sorted.
cheers again for all the advice
My car has a small connection fitted by the drivers left leg on the centre console. I have seen another z fitted with a turbo timer at this position, is this the normal place to fit it and how can I tell which manufacturer's turbo timer the connector is for (if it is) ?
