NZR - MR2 driveshaft
Guys
Me and Spinksy have had a total mare changing the clutch!!! It ended up with the eintire engine coming out due to not beng able to find one gearbox bolt hidden by the side of the starter motor under all the pipes....
ANYWAY, engine is back in, managed sheer a bolt in the air con unit!! GRRR, so thats had to come off and be retapped.....now, I cant figure out the inboard end of the passenger side driveshaft.....
The bearings came out as I was trying to put the driveshaft back in, so, I took the driveshaft off the car, cleaned it all up but I when I put it all back together there isnt any movement in the joint?!?!? I have tried loads of different ways but I cant get the CV joint to be flexible, its just solid!!!!
So, I need to get another driveshaft, 4 hours labour is enough time wasted on a cheap driveshaft.....
The quesiton is, is the driveshaft for the rev3 turbo any different to any other MR2 passenger side driveshaft? If so fine, I'll get one, but I dont want to be offered a non-turbo or a different REV driveshaft if it isnt going to be right?
Does anyone know?
Thanks for your help in advance, I really want to get this finished tomorrow....
Cheers guys... :bow:
Don't rightly know if they are different bud but you could ask on
http://www.mr2oc.co.uk sure someone there will know-probably find a new shaft
while your at it!? ;)
