Octane Booster
Ive been using Lucas octane booster in my Z has anybody else used it ? what are the long term effects of using this stuff.
There is a massive boost in performance with it. :confused:
Bottle of this will do the trick bud ethanol%20-%20rikka%20corridor%20party.jpg
Thats a little more serious "METHANOL" the best smell in the world ? nearly :D
Will a standard Z take a few shots of that without long term damage.
what about that toulene stuff I've read about? supposed to be awesome
whats that then ? :confused:
Aint that what they put in Red Bull?
I used octane booster the last time i filled up and it made my car run boggy at high revs.
I do not seem to have had any problems at all Yet !!! :hyper:
Could this be down to the ECU? As in... If you disconnected the battery to re-set the ECU, then put the Octaine Booster in with a full tank it would then 'Learn' with the 'Boosted' fuel carectoristics(sp?) and run better. Whereas if you don't re-set the ECU, then it'll run as normal fuel!
If you see what I mean?
