You'll be pleased to know........
That i'm back in the garage!-done a fair bit today, made alternator brackets and fitted that, made p/steering pump brackets, wired in alt and starter-she now turns on the key! Also cut slam panel and now the Koyo fits :D -got to make brackets to hold that tomorrow, wired in ignition feed and tacho and fitted a leather gaiter to the gear stick!(cheers Boldy!)
BUT!-I left my camera at work so you will have to take my word for it! :headvswal :D
And you will be pleased to know, your old engine just blew a brand new 911 carrera.......
WooHoo!-Dude you got it sorted! :D -can't tell ya how happy/releived I am for you!
I take it the lump aint' fooked then! :D -c'mon what was it! :o
Legend! :bow:
:hyper: good to hear it Darren. you seem to get more and more done each day. how far through would you say you were mate (or shouldnt i ask? :x: )
Would you believe the main problems were the fooking dump valves.
they were knackered and set far too weak, so were opening on tick over and messing up the idle
also, ecu wiring was dodgy and a maf sensor
Good to hear mate!-glad you stuck with it!
And Dave, to be honest mate not far of now but lack of funds is fookin' me up at the mo'!! :( -I need in no paticular order; A fuel pump, a carb, pair of valve covers, air filter, sh!t loads of silicone hose to plumb it all in!, clutch pedal and cylinder (on order) 3x hose making for clutch and p/steering, 2x v belts, prop modifying and make up an exhaust!-well you did ask!
At least week after next the 2 poster comes so that will make things easier! :D
When you say valve covers, what you looking for ??
Rocker covers ??
Alan...
That's em bud!-nice new Edelbrock tall ones!-got any! :D
Got the camera back so here's the pics!-don't look much I know but a lot of head sratching went into those brackets!! :o and after much searching at last found 2 belts that fit! :hyper:
This is the koyo fitted-only had to remove about 5mm from the slam panel-and yes there is a gap between the pulley and rad! ;) -and no I aint' using that alternator-for pattern purposes only!
darren dont forget that big lump might get a bit of torsion movement on the engine mounts,dont want to see that koyo get a pulley rammed into it :( . but i know you,ve added this to the gap tolerence :nelson:
Dude, Iv'e pulled and yanked at it! :eek: :eek: Beleive me it might twist but it sure won't move for and aft! ;)
looks awesome m8
have u sorted the prop shaft?
how will that link from the box to the rear axle??
u using a standard Zed one? or a different prop?
nice work anyway m8ty, im impressed!! :)
looks awesome m8
That's the easy bit mate!-I got about 2 foot of supra shaft, so I measure up take it all round to Wilsons driveshafts and leave em' to it! :D
mate, thats awesome - cant wait to see it finished!!!
