PC, Laptop, PDA and mobile how do I get them talk to each other
Am I right in thinking that Bluetooth is the sensible option, if so can anyone point in the right direction for the gizmos and programmes I need please?
stick em in a corner of a room give em a pint each and see how they get on..
dont forget the scratchin's! :rofl: :rofl:
you need a dongle plug it in to your usb port
if your mobile and pda are already bluetooth enabled then just get two usb blue tooth fobs, one for your laptop and one for your pc, thats it install drivers and they will sort themselves out by scanning for cnx.
not expensive anymore either under 30quid these days, for the laptop get a pcmcia car that way its tucked inside out of the way.
Do they all have bluetooth? PDA and laptop probably do but as above your need a dongle for the PC probably. Or get a wireless solution Mark, cheap as chips these days and u can surf the net on the bog!
Tell them to make up and shake hands or they're all going to bed with NO ice cream :D
Cheer fellas, was thinking of a wirless solution, which one do you advise mate, be gentle with me?
Mobile and PDA are bluetooth, so just have to get it on the PC and Laptop any bargains out there?
i do these sweex ones if interested.. £20 a pop, boxed with drivers and manuals..
The Sweex Bluetooth USB adapter makes it easy to create a wireless link between a desktop PC and Bluetooth devices such as a Bluetooth phone, keyboard, mouse, printer or PDA. You can also exchange data between multiple PCs or notebooks. The adapter has user-friendly software and is easy to install. You can communicate with up to seven Bluetooth devices at a time.
Specifications
Bluetooth 1.2, Class 2
Maximum distance for Bluetooth connection: 10 metres
Maximum data speed: 723 Kbps
Interface: USB 1.1
Supports: Windows 98SE, ME, 2000, XP and Mac OS 10.1.14 or higher
Additional specifications
Power consumption: 30mA (operation),
Frequency range: 2.400Ghz ~ 2.480 GHz ISM Band
Sensitivity: -80dBm @0.1%BER
Output voltage: 5V
Operating temperature: -10 º C ~ 55 º C
Dimensions: 45 x 22 x 8.5 mm (l x h x w)
Weight:
