protoj · Tuesday at 18:48 4 days
Hi, i've currently got a 200 and been longing for a 300 for a while, a friend of a guy I know is selling his 300 and it seems like a good deal its a 91H uk manual with 106k on the clock in red. I've read the buying guide on the club site and from what I can gather high mileage early cars can be more trouble than they're worth????
any help much appreciated
