October 6, 200521 yr hi guys i need a bit of help fixin my car when i push the peddle down it makes a buuzzzz noise sounds like a electronic senser or some thing it dont do it all the time but most of the time
October 6, 200521 yr from member i seem to recall this is down to the fuel pump, and something to do with when it switches from 12v to 6v, i have the same problem on mine which i kind of live with, but will one day get sorted. can someone else confirm...
October 6, 200521 yr u can kinda feel it threw the peddle it only dos it when u move the peddle up/down like its a senser messin up but i dont no ??????????
October 7, 200521 yr On the bulhead in the engine comparment there are solenoids which operate things like the aiv`s and the egr, they can become noisy in operation and are sort of behind the accelerator pedal, the buzzing feeling could be transmitted through the panel. These solenoids are easy to change if they are the problem, used parts will not cost much either, try from under the bonnet just slightly pressing the throttle cable with the engine running and observe any excessive noise or buzzing from those solenoids. Jeff TT
October 7, 200521 yr cheers for that Jeff, good to see you still around, no doubt i'll be coming over with the Z at some point soon for a once-over. btw did u manage to expand into the spare barn and setup the shop you where telling me about?
October 23, 200521 yr Quoted By doxtoby "btw did u manage to expand into the spare barn and setup the shop you where telling me about?" Yes sure did. Jeff TT
