Broadband speed check link??
I'm after the link to the site that does the Download Speed checking, that was posted on here a while ago. I've been looking and just can't find it anywhere.
I've checked out some other ones on-line, but they give the result as one figure, where-as this other one showed you both the Download and Upload separatley (if you see what i mean ;) )
TIA
767.6 Im fairly happy with that!! :)
goto http://www.broadbandreports.com
theres a tweak test you can do, and then enter your system cpu etc and line spped and it will give you settings to enter into a program you can get from there called drtcp, with this you can spped things up a bit, my adsl connects at 2.8 mb on a 2 mb line now
http://www.broadbandreports.com/tweaks
my old report
1. Your Tweakable Settings:
Receive Window (RWIN): 17520
Window Scaling: off
Path MTU Discovery: ON
RFC1323 Window Scaling: OFF
RFC1323 Time Stamping: OFF
Selective Acks: ON
MSS requested: 1460
TTL: unknown
TTL remaining: 109
2. Test 146000 byte download
Actual data bytes sent: 146000
Actual data packets: 100
Max packet sent (MTU): 1500
Max packet recd (MTU): 1500
Retransmitted data packets: 0
sacks you sent: 0
pushed data pkts: 15
data transmit time: 1.149 secs
our max idletime: 146.3 ms
transfer rate: 83205 bytes/sec
transfer rate: 665 kbits/sec
This is not a speed test!
transfer efficiency: 100%
my old report
Window Scaling: off
Selective Acks: ON
MSS requested: 1460
TTL: unknown
TTL remaining: 109
sacks you sent: 0
Did the above and got this: Service: isdndslcablewirelesssatellite Speed (advertised) kbit/s: Operating System: win95win98win98SEwinMEwinNTwin2kwinXPMacLinuxFBSDSolaris Connection: normalwinpoetwinXPpppoerouterpppoeraspppoeenternetpppoA
Window Scaling: off
Selective Acks: ON
MSS requested: 1460
TTL: unknown
TTL remaining: 111
Actual data bytes sent: 147460
Actual data packets: 101
Retransmitted data packets: 1
sacks you sent: 11
data transmit time: 2.886 secs
our max idletime: 218.6 ms
transfer rate: 41795 bytes/sec
transfer rate: 334 kbits/sec
transfer efficiency: 99%
3. ICMP (ping) check
Target unpingable
Notes and recommendations:
Choose RWIN between 5840 and 10220 (FAQ #586)
download/use DRTCP .. (FAQ #578)
Read the tweak FAQ
Good data stream (no/few rexmits)
Become pingable
if you need basic packet loss tests done
Check tweak FAQ
Now what??
Just installed that, and run it, re-booted, and it's made NO diference what-so-ever :D
This any good????
Window Scaling: off
Selective Acks: ON
MSS requested: 1460
TTL:
(less any hops behind firewall)
132
TTL remaining: 118
sacks you sent: 0
data transmit time: 1.013 secs
our max idletime: 96.8 ms
transfer rate: 100712 bytes/sec
transfer rate: 805 kbits/sec
:confused: :confused: :confused:
I got 253 K/s - 2024 Kbps... no idea what that is but I got a smiley face. So that was cool. :D
anyone else on Blueyonder 4meg
I got 972Kbps on one test and a transfer efficiency of 99% on one of the others
I'm happy :D
well the first section is a settings list for you to enter into drtcp. when entered restart the pc, also remember that you can set the RWIN number to higher setting this will speed things up however dont over do it or you will suffer from data stuttering as it will not process fast enough
