I think this will have to do?
I have finally done my clocks. I tried to make my own faces but they was too much hassle. I would like some coloured faces but am quite pleased with the look at the mo. I have mounted the alarm L.E.D. in the middle which is very effective and very visable to the thieves.
I think that when I have got a ally dash kit installed it will all come together.
:hyper:
Looking good Bud, keep up the good work, but you might need to stick some more numbers on the old speedo, as it only goes up to 120 mph. LOL
Viniboy have you fitted the speedo rings as well as the stainless bezel ? :confused: looks sweet :D
I know what you are saying thats the only thing that bugs me. I bought these ones from Chunk a way back and have fooked the 280KPH faces :confused: But I am quite an expert now with stripping them down so it wont take long to change later on. I have set the speedo to my sat nav and its spot on. so I will buy another set when I find them and start again.
Viniboy have you fitted the speedo rings as well as the stainless bezel ? looks sweet
Yes they look OK dont they mate. It was a bit fiddley because the rings are made to fit the actual clocks assembly and the Bezel has slightly bigger holes. so I fitted the bezel and placed the rings on after. using "No more nails" it takes a bit of time to dry but you can position the rings with ease.
Looks nice mate (he says, while thinking ... should i copy him... :D )
Have you got a tom tom go 300 if so how do you do this?? cheers
No mate my tom tom is on an ipaq. But to do it I turn off navigation and get to 30 MPH and hold it there. I do ir again at 50 80 and 100MPH and check the diffences and establish a common reading and turn the speedo needle up or down to compensate. If that makes any sense?
Its not copying its being inspired. I am getting the same front bumper and lights(rear) as you...........You see I am inspired. :bow: :rofl:
