anyone ever done this???
hi all i have uk spec lights etc ,
just wonderd if anyone had ever replaced lights with j spec as i think they look better,,, i know the simple bit ie changing them over its just the wiring part can it be done what do i need, ,, ie jap side lights to replace uk spec and put fog lights on instead of the blanks on uk spec??
hi bud conveted mine to j spec it's quite easy to do i kept the sidelights in the fogs then moved the indicators to the front corners only mods i had to do was
1. cut off the orginal sidelight bulb holder so i could solder it to sidelight and earth wires on the fogs
2. extend the indicator earth wire to fit to front corner
3. wire fog lights through a relay and switch so they work with dip beam
at the same time i bypassed the dim dip system as my passenger side dip beam worked when it felt like it,to do that all you need to do is cut the passenger side dip beam positive cable and connect it to the positve on the main beam as it is switched by the earth cables
hope this helps kev
do us a drawing
