protoj ·
Nissan wants to be the first car manufacture to allow customers to customize their vehicles over the web.
a bit like waht Dell does with pc's.
http://update.internetweek.com/cgi-bin4/flo?y=eFdP0BzmnM0V30BE8r0A2
