Fitted one of these
Exedy - Multi-Plate Racing Clutch
For high-powered applications, Exedy offers twin and triple Multi-Plate Clutches. These are designed for road use as well as drag, Race track and rally use. The Twin-Plate clutches are rated for above 500hp to 705hp. The Triple-Plate clutches are rated for up to and over 1000hp (for drag race applications). Twins come with both spring damper discs (SD type) and solid discs (SR type). Triples are all solid discs. All multi-plate clutches come with a lightweight, chromoly steel flywheel and the famous purple anodized forged aluminum clutch cover.
This is an awesome bit of kit from dpmotorsport. Fitted a twin carbo alloy plate and its as smooth as butter. It feels a little heavier than a standard clutch, but not much.
Down side if there is one is that being a twin plate it rattles when you engage it, but you can drive round town all day and then ride the thing to death if you want a real fast get away and it'll take it until your Zed is dead.
Its the next best thing to the RPS carbon clutch at 2 thirds the price.
sounds nice, always worth getting a good clutch. I should know, on clutch number four now
Carn't recomend it enough. It really has impressed me + JD had a little dibble with it today and seemed equally impressed.
