protoj ·
Happy New Year!.......I see some of you are all still squabbleing as usual. Some things never change
I would include a link to my new site PORKERS WORLD but I doubt you would be able to handle the high BHP figures contained within!
Bye for now
[This message has been edited by Porker (edited 06-01-2002).]
