Fitting a HICAS Eliminator
Another job im about to try is fitting my new TOP SPEED PRO 1 PERFORMANCE HICAS eliminator.
I have no instructions - Anyone have any - is it an easy job?
same here, ive got one but wouldnt mind some direction about fitting it..
if there arnt any up in a while il scan my stillen ones for you guys
You are the man !! :bow: :bow:
O....Just remembered.....I had done a thread on this somewhere but cant find it so heres what i remember...
My zed had a different rear hicas rack to the one shown...my pipes were situated at the top of the rack..not the back as shown.
Krsmayo has the one shown and is an import but mine is also an import but had a different rack to his....
Also...
The little unit that the bypass pipe fits to was different to the one shown and my little bridge adaptor didnt fit as my pipe outlets were at a different angle to what the bridge adaptor was made to...so the hicas line feed was just cut at the metal pipes and fed back on itself...this unit by the way is tucked up near the underside of the rear left passengers seat...not too obvious to begin with.
Do a search and you might get lucky :cool:
When you remove the banjo bolts - im presuming steering fluid is gonna come pissing out?
lol, yep! not too much though
sound - will i need to top up the power steering reservoir with 4.1?
top up with dextron III (ps fluid or at fluid). Won't need much.
