Diff Leak
hi could anyone tell me if there diff has leaked from the drive shaft coupler because mine seems to be. It only seems to do it when been driven parked in garage its fine but after driven the underbody of car were the driveshaft meets the diff is covered in oil checked all pipes to brakes and Hicas and brake fluid and power stearing fluid not moving. can you replace the oil seals on diff? :rolleyes:
are you sure it's not from the gearbox seal? It will cover things as it is rushed back while driving (does that make sense?)
Vijay
Vijay
oil only at the rear no were else
what I mean is the oil will spray towards the rear of the car while your drive, seen it happen on another Z :)
Vijay
