protoj · Tuesday at 18:48 4 days
in the dark aswell!
Would like to thanl all those that have posted details on upgrading lights with the halfords substitutes.
Last time I bought a bulb I paid ~£34 from Middlehurst, and at that price I was never likely to upgrade the bulbs. 2x 30% brighter bulbs £15.98, connectors £1.09 = night vision.
MCZX
