Two questions
First what should the standard boost read in bar is it 0.7?
ย
How do you adjust the clutch biting point?
ย
Found a nut behing the pedal but doesn't seem to do anything....
The bolt behind the pedal will adjust the bite point up n down the pedal if you can bend yourself double n turn it. Dont do as I did n adjust the brake pedal n couldn't understand it not making an differance to the clutch :xxx: . It is all a bit confusing when your upside down n inside out lol :rolleyes:
as the cluth is hydraulic i dont think you can adjust the bite point if your is starting to bite quite high the clutch maybe worn and needs replacing
ย
LOL, that sounds like a problem with the nut behind the steering wheel ;) :p
ย
FPMSL :rofl: :rofl: You might be right......... :rolleyes:
