burning a dvd
how do I burn back to dvd..
I have some DIVx avi etc files on my computer..
and want to burn some back to disc to play on my dvd player
I can burn music cd's fine.. dont you have to convert files etc?
but then will the disc play the file full screen on a TV if its only just big enough to go on a 14 inch lap top screen before it goes blocky and poor resolution...
any info appreciated
thanks
chris
got some dvd disks ready!
thanks
chris
hi chris you need 2 programmes to convert files back to dvd the first is cucusoft avi to dvd mpeg converter this converts to a dvd compatable mpeg the second prog is cucusoft mpeg to dvd auther which takes the converted mpeg and turns it into vob files ready to burn straight to a dvd (i use nero 6 then just copy the vts files into the vts folder on the burn engine under the dvd video menu) hope this helps kev
thanks
chris
hi mate i use a prog called winavi i can send u a copy if u want, very fast and easy to use. encodes the video very quickly and once done just use nero copy and paste then burn job done.
for one off easy to use , it has to be dvd santa, you just select the file, tell it if you want pal or ntsc, and the resolution and screen settings and off it goes, takes about an hour to transcode it and the audio in one go then it will just ask for a dvd and burns it.
i did a xvid of the guns of navarone last night, it was on two files spread over two cds worth, i just put both files in to dvd santa and it automatically joined them and burned hte film in glorious vision to dvd. and the verdict!! fan bloody tastic.
i will bring a few things to ross on wye just in case someone wants a few things.. ahem..
