Driver's side electric window- power amp
My driver's side window is poorly and having stuck a multimeter on the window amplifier output I reckon it's feeling poorly. :(
Anyone got a wiring diagram of the amplifier internals? :confused:
I might make my own replacement, but I'm not quite sure how to get the one-touch operation...
(Will trawl the rest of this and other forums later today)
Mark
hello mate i had exactly the same problem! cost from nissan £137+vat
i took mine apart and found it was just a dry solder i resoldered it and works as if it was new again give it ago
gaz
Oh nuts it was fine for a while then it stopped working with the windows down yesterday!
Where's that soldering iron...
lol mine did that i travelled to do some leasurely shopping at poole quay..tops off windows down.when i finally found a space in the carpark went to put the window up doh!!! f@$k tried everything to get the window to go up.... no nothing got home took apart the amp assembly and resoldered a dodgy joint..works a treat now like new and faster than b4
Just did it today- yep there was a really bad dry solder joint, so I did that and a couple of others that didn't look to good.
Works a treat now! :dance: :nana2:
Cheers Hellraiser,
Mark
