Electric Aerial fitting
My standard aerial wouldn't retract fully, no surprise there then, so i've got an autoleads electric aerial from a local motorfactors, i've wired it up as the original was but i can't get it to work, this is the second one so i don't think it's the unit itself.
Has anyone else had the same problem?
Baz
those universal ones come with the timer relay inside them already, when i did mine i took the live and switched feeds from the original arial timer relay on the rear wing and wired them straight into the new arial. i cant remember the colours of the wires you need but theres a cracking diagram on the online service manual. check your fuse too, when the old arial stuck it might have taken the fuse with it.
