which boost controller?
Does the Profec E actually double as a boost gauge? Or am I being a duffus???
yes, and then some :
GReddys new super multi-tasker is the PRofec e-01. Designed as a combination: boost-controller, data display / logger and e-manage programmer, the e-01 can provide superior boost response, increased boost, warning meter functions, 3channel data-logging, and access to all the programming features provided with the latest e-manage support tool. Even when used as just a boost controller the e-01 has features to smooth out the boost curve. With both an Auto and Manual setting for both external and actuator style wastegates, the new PRofec can alter its new compact, high capacity solenoid valve via various RPM ranges if need be. The large LCD screen, with green elecro-illuminesant backlighting is easy to see. Other standard features includes two preset boost levels, a timed over-take boost and compatibility with our Remote Switching System. The data display can view 3 different data channels simultaneously; like Boost, RPM, or any other channel inputted by the emanage. The data can be logged up for 3hours on a SD card while also giving warning set points, and peak & hold values. (Some features require optional harness to be access)
Profec E-01 :bow:
slight hijack...do you have to use the LCD screen that comes with the Profec E-01, or can you use another screen (as I already have a screen and dont want two in the car)
any thoughts on this ebay GREDDY PROFEC B-SPEC 2 II BOOST CONTROLLER over the apexi avcr?
Nice simple controller to use. Fits in the 300zx Clock position for a stock look.
E-01 no comprimise!
Depends on how far you want to take your modding, if you want a simple to use controller then the Profec is for you, if you want all the features bells and whistles then the AVCR is your unit, some issues with AVCR's just try to be lucky and not get a faulty one.
Both can be bought through me, PM me for more info :)
