they do 50mph :shock: and they go for about £120
http://www.minipocketrockets.com/rsr.htm
It only does 40 mph and how much will postage from America be for that???
Drivetrain
Engine: 47cc Single Cylinder, 2 Stroke, Air Cooled
Fuel / Oil Ratio: 50:1 (unleaded gasoline & 2 stroke oil)
Starter: Pull Start
Maximum Speed: up to 40 mph
Ignition: Magneto, High Discharge Coil
Transmission: Centrifugal Automatic (chain drive)
Maximum Power: 4.4 hp
Brakes: Front and Rear Cross-Drilled, Slotted Discs
Exhaust: Mandrel Bent Pipe and Silencer
Dimensions
Length: 39"
Width: 24"
Height: 22"
Ground Clearance: 4"
Dry Weight: 38 lbs.
Weight Capacity: 290 lbs.
Fuel Tank Capacity: 1/4 Gallon (1 liter)
Cruising Range: 15 miles per tank
Tires: Pneumatic GP Racing Slick Tires
