Starter Motor Question...
Should the cog on the right turn without any power?....as i cant get it to move either way.
The main setup all turns and moves freely now after I have greased and lubed the shaft :eek:
Reason being that it just clicks and throws the cog out when I go to start and the SMotor is getting very warm so I reckon the powers getting their.
I have checked all my connections and are now good.
sounds like its fooked to me.
shouldnt get hot mate sounds like its burnt out ive never had a starter get hot in any of my cars...
Pleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeease :D
It's shafted, should'nt get hot, they do get a little warm bot not hot, get a new or s/hand one
Okeley Dokeley
Thanks peeps :hyper:
...how old's the cars battery? I had the same once and it turned out to be the battery was failing. I'd removed the starter motor - pulled it apart and re-built it (relatively easy to do) and the starter would still jump into gear then out again, without trying to turn the engine.
Everything pointed at the starter - or so I thought, as I'd assumed a poor battery would have just turned the engine slowly. No so - these clever Japanese have it that the stsrter won't engage if there's not enough power to turn the engine.
Good luck
Jack
Hello jack...
I have one of those batterys with the LED on the top to tell you if its charged or not...
And its showing bright green to say its fully charged :confused:
I will test it tonight with a voltage tester and see if it says any different but I reckon its ok.
Thanks for the idea bud ;)
might be fully charged but is there enough cranking amps? IIRC our Z's needed a pretty high cranking ampage.
Vijay
Vijay
Is there anyway I can check the cranking ampage as opposed to just the level of the battery please?
I know a good battery should read about 13.1 volts and a brown bread one would read about 12v...
I don't know the answer re amps, but how old's the battery. If it's 3 years old, you've got to be looking at a new one soon... Only speaking from experience... Can you borrow a good (known) battery from another car just to test the poor-battery theory?
Thats a simple idea I never even thought of....CheerZ bud... :bow:
I dont know how old the battery is as I've only had the car 6months....it looks fairly new but then batterys always do dont they :(
Yes, but don't try with a multimeter :D
To measure the current drain, the meter would have to be in circuit with the starter - i.e. all of the starting current would need to flow through the meter.
You'd need a serious meter for that, with some very chunky wires ;)
will it start with a jump start?
Vijay
Nope...tried that one....didnt work mate :(
To measure the current drain, the meter would have to be in circuit with the starter - i.e. all of the starting current would need to flow through the meter :eek: .
lol...wont be triying that one then... :wack:
I have now checked the battery and its holding about 13 to 13.1v...
So I doubt its the battery...
Im having a second hand starter motor delivered tommorow so
The proof is in the pudding...
Only time will tell...
I wont count my chickens...
:headvswal shut up steve :headvswal
With thanks to AndyZ ;) I have sourced a starter motor and got delivered today and then I fitted it tonight.
It works now
So it must of been a burnt out motor :wack:
Anyhow...3days without me Zeeeeeeeeeeee and I was starting to feel sad :(
But its back now :D
woo hoo glad your back burning rubber dude the darkside is feeling stronger once more!
"YODA".......mmmmMMMMmmm...Start the car it will
