ive got a 1990 uk TT man and have had it for about 6month now. and ever since ive had it its had this realy odd prob of not turning off! starts fine its wen ya want turn it of. this prob is intermittent! iff you turn the key to off (once running) the engine will drop a few revs and just sit there! so i have to keep unpluggin the CAS lead lol.. and help would be much apriciated
chears :cry:
i know this is a silly question. but does it have a turbo timer? If it does, thats more than likely the reason.
I own an N/A, so i dont know for definate but dont TTs have a timer so when you turn the ignition off it keeps running for a couple of minutes after something to do with the turbos??
any can can have a turbo timer. Its only called so to allow the turbos to cool down, but it will also help the rest of the engine, so benifical to none turbo cars too
nope, no turbo timer!
what could it be.. realy doin me "nut" in :confused:
mmmmmmm ill have a look at the relays and try soakin the ignition switch in contackt cleaner!
any other thoughts..
much apriciaded by the way :cool: ;)
it will be your ecu.. swap it with someone else to prove it though first before you go buying another one.
AdamR had the same prob on his a while back.
Saw this EXACT same fault several weeks ago, the owner of the car had previously had the ecu repaired due to some other kind of fault but when refitted would not shutdown on the key however the revs dropped slightly.
A replacement ecu sorted the problem, at the time I put it down to maybe a faulty track solder when previously repaired, however in light of you having the exact same symptoms there may be a particular component in the ecu that can be damaged and back feed a live suppy to the ignition switch, unless of course your ecu has had a repair in the past and has been damaged, if you want to borrow a spare ecu to try it out give me a shout not far from you.
Jeff tt
I thought most of AdamR's threads were titled "My Zed won't Start!"
:D
Jeff tt
thanx all of you! ya bin a grate help! i have alot of stuff from Z1 in the states! gettin know em realy good! so me thinks if it is that ill get them send me a chip un ova. unless any of ya know good places ova here get them from! ps jeff tt ya work/own zedworld by anychance? :cool:
Gareth had the same problem on his a while back, diagnosed as ECU, replaced it and problem solved. If you haven`t got the cash for a new ECU i can rewire a relay under the bonnet as a temp fix.
Bob
Yep!!
Jeff TT
And he's a very nice fella too...........even though he keeps breaking My Zed mirrors :rofl:
So funny you mentioned that, the last mirror you sent is still here
( in bits!.........damn shame ) some one was admiring your handy work but not that of the parcel company who broke it!! did mentioned they would like to order one from you once a suitable carrier is found.
Jeff TT
Bob
if ya could tell me the basics then ill most prob sort it!
Yep!!
Jeff TT
i rang you a week back after a engine lol. decides rebuild mine up insted! ( makin her super de duper strong in the process ) :nana2::nana2::nana2:
Jeff TT
Am heading over mid-August for a wedding so I'm bringing yours with me (managed to talk the old man into lending me his range rover, so plenty of room!), If the other guy is serious , my e-mail is
mickandadell@eircom.net
I could bring that too and leave it at you're place for collection if that's ok.
