Att. macca
just can't find a driver of the right size to take the clutch apart, dam i so wanted to see what the fly looked like. still more mc'ewens :duffer:
SHIT:( Oh well this is what she looks like opened up and welcome to the exclusive 1.7k clutch club :wack: :D :duffer:
ย
Macca, I hope your Apexi intakes can take some punishment cos those 18G's are going to suck rabbits out of the fields! Now the TD05 turbos running at only 6psi will demolish a Z running 1 bar on stock tubs,what will it demolish running 20+PSI?:wack: :D :duffer:
ย
ย
Probably the Pistons :)
ย
ย
ย
No the engine will take alot more than 20psi :duffer:
Hi MAC . Just bought a UK TT Manual with no mods as yet. Whats the safe boost level for a standard motor with the induction and exhaust changed. What about chipping ??
ย
Craig
ย
Craig
ย
Providing that your engine is in good condition and that you are running stock turbos and stock injectors around 14psi.
You need to have your ECU socketed and a new chip.
Ok who do I speak to for chips? I can get the socket fitted no hassle mates electronics tech.
ย
Give us a bell and we can sort both a chip and a boost control solution :)
Ok Chris
Kinda cost are we looking at? I'm doing the car my way. "Make it fast but look standard"
Craig
Boost Solutions from ยฃ40-500
Chips from ยฃ50-130
ย
All depending on what you want, just ring on Monday and i'll sort you out :)
Ok Chris will do .. Not looking for anything to mental as the motors fast enough to leave most things behind as is. Just fancy having somthing a extra if required :)
