Fixed the fuel smell - now got a water leak!
In the last couple of days noticed a smell of fuel.... this morning when i got in - it was so bad that I thought it was dangerous.
So I opened the bonnet and found a loose hose clamp under the plenum cover... i managed to tighten the screw with 10 turns!!
Great - drove to work without being under the influence of fuel inhalation.
Parked up and noticed water pouring out from under the car.
If you look from the passenger side just behind the front wheel under the passenger footwell there is a hose - the water seems to be coming from there....
Any ideas what this hose connects to?
sounds like the expansion tank is overflowing bud. do a search on it , seems almost every zed has suffered from this through one cause or another!!
that could be your air con hose, it's supposede to do that. Did you have your aircon on?
Vijay
It could be the xpansion tank has cracked and is loosing all the water. If you remove the front wheel, then take off the innser shroud you can get right to it - there is a pipe right at the bottom of it - sometimes the plastic part on the tank breaks.....
