bonnet rattle
have had a noise which i thought was behind my dash... it turned out to be the bonnet rattling/squeeking at the hinge.
on closer inspection there is a little bit of play about 1-2 mm in the pivot point of the hinge ...tried the usual wd40 trick but it returns after a couple of minutes help... is the any way to tighten the hinge up of disasemble it to put plastic washers in ect
Matey, had the same prob myself. What i did was WD40 the hinges and put some Grease on the main catch. Just applyed when ness!!
[sIGPIC][/sIGPIC]
I had this same rattle too, sounded like it was coming from behind dash. Anyway later found it was the passenger side bonnet hinge, the pivot bolt had worn causing play which allowed it to chatter especially at higher speeds.
TBH your better of getting a replacement hinge maybe off one of the traders with no play in it... :duffer:
cheers Jon.
Its not the hinge it's the catch.... If you look, I bet the plastic coating on the bonnet side of the latch is worn. If so it will rattle and squeek..
Chris..
no its deff the hinge put hand out of window while driving held the corner of the bonnet and rattle squeek stopped when i opened the bonnet and tried to move it side to side there was about 1-2 mm of play at the hinge pivot point
Thats exactly what I did lol, got me missus to drive me zed eek :x: Whilst I put me arm out the window to press the bonnet down :rofl: ;)
cheers Jon..
I Wasnt That Brave To Let Her In Draws Drive She Hasnt Got A License (phew) Just Had Me Chin On The Steering Wheel Lol
Nice One
Chris..
This noice drove me mad for fookin ages before i knew were the noise was coming from, then i wrapped tape around the catch problem solved.
Stick a bit of insulation tape round the catch it will stop.
:confused: Ok I think we've established it is the hinge and not the catch :slap:
cheers Jon..
cheers Jon..
Ok ok :eek: then stick some tape on the hinge :D
BET YOUR WRONG!
It's the catch, bin there done that.
Oh and the tape works, thats what I done..
Chris..
I agree with you dude a scuba diver says its the catch.
:headvswal :headvswal :headvswal :D
