Heating,speedo,hicas,probs
Please Help
No1
I Have A 1991 Import Tt The Speedo Has Been Converted To Mph But Since Owning The Car It Has Hardly Ever Worked I Also Have The Hicas Light On.when Starting The Car The Steering Is Light But Shortly After It Stiffens Up Any Ideas?
No2
The Heating Has Also Packed Up When Trying To Turn It On U Can Hear The Directional Flaps Moving Into Position But No Hot Air,cold Air Comes Out The Revs Also Rise And Then Drop Again After A Few Secs Please Help If U Can?
Please Help
No1
No2
right in short it needs lookin at,for the hicas light check the power steering pot for low fluid but if IIRC stiff steering dodgy speedo comes together with poor intallation of de-limiter and possibly effected speed sensor check the wires behind the clocks
as for no heat possibly heater matrix failure have you had any wet patches in the drivers footwell??
use the search facility as a lot of people have had the clocks/heavy steering problem
Thanx 4 Ur Reply Ill Have A Look 4 The Wet Patches In The Footwell I Havent Noticed Anything Would It Be Alot 2 Notice? Plus What Would I Look 4 Behind The Clocks. P.s Nice Z Is It Rosso Corsa Red The Same As Mine?
