Help!
jacked the car up and removed the undertray, laek is deinately not from rad or overflow, coolant dripping off the underdrive pulley so im thinking water pump? could it be anything else?
ย
right thats as far as i can go because i simply dnt know what to do next!
all advice welcome guys
ย
yaseen
call me if you can
07763628667
check main water pipes aswell sometimes it can leak there,but like you say more likely to be waterpump
Water pump, or the two metal pipes that go into the head. If you end up replacing the pump, then I'd strongly recommend you do the pipes at the same time, they only cost a few quid each and being steel they tend to rust away from the inside.
ok, so seeing as its too big a job for me to do in a day and i dont want to rush it, im gonna leave till weekend after next probably.
ย
what should i do at the same time and what do i need beside new water pump and the two short main rubber pipes?
ย
ย
ย
Good quality sealant,change all your belts,dont forget crank pulley to come off,so good long Torque wrench/sockets.PIA all of it :(
ย
Tony
ps,rip your aircon out :D
thanks guys, just remembered the car hasnt had its 60k service yet but its very nearly due so is anyhting else i'll need apart from whats been mentioned?
ย
Tony, i would take it out if i had targas but i dnt fancy being stuck in traffic in my slicktop in th height of summer without the AC!
ย
ย
:x: agreed ;)
...you need some long-reach allen keys too...
ย
good luck
ย
Jack
ย
good luck
ย
Jack
ย
And bloody good ones too - I busted one of my Facoms, those bolts can be tight !
ย
ย
an allen key socket with long extension on ratchet helps,that way theres no leverage on allen key
