Anyone running T-28 BB turbo's with standard injectors?
Just wandering what my tuning options are as I can't afford to shell out for bigger injectors just yet. The car already goes fairly well, tubs spool very quickly and it has decent mid range running 10 psi, de-cat powerflow, cone filter and JWT. Think the boost is upped just a touch with one boost jet only.
I assume that running 14 psi on my Profec if I get it installed will max out the injectors due to the bigger tubs?
Also have an SAFC...some like them and have got good results, others prefer a custom chip.
Cheers all :)
Yeah, you'll max out your injectors. If you don't want to shell out on injectors you can try an adjustable FPR to get a bit more, but the only way to know for sure is get it hooked up to a wideband and check (I have one).
SAFC is a crude and horrible way to tune. It makes no allowance for load, and the corrections you need at full throttle will be nothing like you need at low load for the same RPM. They also mess up the timing.
Cheers John. Looks like I need another trip down your way then! Will sort it out with you soon mate
