The steering is active, so itโs uses input from the speed sensor. If the speedometer fails to work it will stop the power assist steering. You car being an import will likely have a speed converter behind the dash, loose connection here on this circuit will be the cause. You tapping probably remade the connection. Also the speed sensor on the gearbox can pop out the end, be loose, simply slowly down and speeding back up it can kick back to life.
By
Stephen ·
im going to bed and am putting my pj's on cause its getting cold goodnite everyone
