Nearside mice....?
got a squeak coming from the nearside front suspension, sounds like I have a load of mice hidden under there! Can't work out where it's coming from and only happens when driving, can't replicate it on my drive, almost sounds like somehting needs tightening, any clues as to what?
sounds like the upper link arm. i have read a few post as i have the same problem a temp fix (and i mean temp) is to spray the link with wd40 but the squeek will soon come back.
its wear in the arms bushes (so i have read )hope that helps if its something else i would also like the info
cheers
may be a leaky shock.od try spraying all the bushes until the squek goes,will only cure it short term though
Had alook around and thought it could be a leaky shock too but no evidence of it, I'll spay the bushes this weekend. Looks like a new set of bushes is on the way then! Had to be done anyway before I take the car drifting....anyone know what a full set of bushes for a zed goes for these days?
I have a squeak on the off side, doesn't sound like suspesnsion though, more like the wing or something behind it. Does it only when driving and when i shut the drivers door. Any ideas on this one,
Oops, sorry, hijacked
Someone told me that brake fluid is good for stopping bush squeaks, not sure if there's any truth in that tho!
