Fookin Rubber Pipes!!!
how many rubber pipes do these cars have !! After 11-12 years obviously they gonna all start to be brittle and perish but they are everywhere!! And changing them is almost impossible unless u have very small hands to get in the nooks and crannies!! I recon they should all use the majority of metal pipes , then never have to change them or maybe only a couple !!
Tell me about if, I'm up to about £300 spent on fooking rubber pipes, during the last engine change, :headvswal
But then Nissan would not be making another fortune out of you in replacement pipes. :nono: There's method in their 'madness' ;)
I know what you mean though, it's real PITA that just when you think you've found the final leak, another one starts from somewhere else. :headvswal
i recon they should do a rubber pipe replacement kit , to change ALL the pipes !!
should of got ryan to do them when you had the engine out :confused: just think of all that skin you'd of saved :D
he did change most mate , but found one little bugger that looks fine but just started to go , so changed it already but dam those rubber pipes!! good job ive had all the useless ones removed ..i.e. under the plenum and clutch booster ect..lol...the less the better !!
