How to fix speedometer/odometer?
Hello All
My 300zx 1990 NA broke the odometer just a few weeks ago. The trip, speedometer and the odometer are NOT working, the rest of the gauges are working fine (fuel, temp and oil pressure).
How do I fix this problem? :confused:
lol what speedo cable?
it is ran by electrical signal by a speed sensor on the gearbox good luck in finding a cable
Speedo cable ???[/quote
Yes the speedometer, how can this be fix? where is the sensor placed?
Thanks :confused:
The problem I had with mine was the speedo, odo and trip were intermittant, the needle would flick up to the speed I was doing and back down to zero again. I thought it was the convertor as its a jap spec (kph to mph), turned out to be the speedo is self, I removed it and resoldered ALL the components, never had a probelm with it at all !
Is this any use?
http://www.angelfire.com/geek/vg30dett/Cluster/Fix_Cluster.htm
just nicked it off Vijays thread
Thanks I will try that, although the odometer is not working at all.
Also a friend of mine said to check the transmission cable, is this true?
