Alarm Remote Key Fob
:confused: Anyone know the best / cheapest place to et a replacement 300ZX standard alarm keyfob for UK car? Or can you but an alternative or aftermarket keyfob that can be programmed. It's mainly the casing that is falling apart. I expect a clean of the contacts may help? Cheers.
didn't know they came with a standard alarm?? unless uk ones do???
if they don't it sounds like an older alarm and you will be hard pushed to get a
replacement fob, and deffo never heard of a universal one
I beleive it was an option, well on this Jap options list it is anyway....
This is probably a stupid question, but have you tried Nissan? Failing that try MJP in our traders section.
Techtronics in Manchester will do you a copy 01618726275
Bob
Cheers for your help. Nissan have been near useless. Though Nissan logo alarm keyfob and supposed to have been fitted as an option when new they can't trace model or how to get replacement even when desc given of keyfos and the codes printed on a sticker inside. They stated most were Max2 alarms. Not trace on google. Tech-tronic Manchester have told me must be rebadged Cobra alarm for Nissan. Codes given and they said they can do a new fob for £36 on the spot! Also found another uselful site http://www.alarmremotes.co.uk/ who will do for around the same price. They also do one which will scan your original. . Just re-soldered mine and taped up case and works ok for now. Will order the spare though. All in all, been quite a useful experience.
Tech-tronic Manchester said they can do a new fob for £36 on the spot! Also found another uselful site http://www.alarmremotes.co.uk/ who will do for around the same price. They also do one which will scan your original. .
:bow: good work that man. might be woth pasting this info in the ~FAQ area incase anyone needs a replacement fob in the future?
Bob
good luck i used em once...for a different type of car...sent me a fob which was impossible to set up even after several calls and many many fruitless minutes sat in the car tweaking the pot...but they forgot to bill me so fairs fair i guess...:)
