Prop Bearing
When replacing the prop center bearing do you need a press or a special puller to remove it, or can you get it off with a tapping stick....
hope to be doing this on sunday, so if anyone wants to help, i've plenty of liquid refreshments.
Hi Baz,
I think Matt used a vice and a hammer to knock it off when he did mine for me.
Thanks again for the bits last night mate:)
Hi justin,
Have you fitted the bits yet? if not, why not? Good to see matt, you, and your GF(sorry forgot her name) lastnite.
It looks like i will be giving the bearing a good clout with a big tapping stick ? as i ain't got a puller, (anyone ?)
I have made arrangements to pick up my new suspension in the morning so i will be fitting that on sunday, will keep you informed as to how it goes.
When i remove the AC compressor i will give you a shout, should be in the next few weeks.
I still can't belive that a dog caused that much damage to your car m8 ?
adjustable tapometer does the trick lovely, just dont forget to mark the prop :)
Hi justin,
LOL, give me a chance mate! All things being well I will get them fitted on Sunday.
Was good to see you too. My girlfiends name is Kat btw:) That made three of them in the back on the way home!:D
Good luck with the shocks, sure they will go on well. Its going to be an awsome car when its all done mate:)
I'm sure Matt would appreciate the compressor when it comes off your car.
Thanks again for everything Baz,
Justin:)
would that be the metric version or the imperial ?
Always the imperial, whoever used a .90kg ball pein? :smash:
