Manual TT engine loom. Same as Auto???
I'm going to get a new engine bay loom (well the big and Small one). Are the manwell TT looms the same as the Auto TT looms and if not whats the difference?
The auto one has a couple more plugs on it for the slush box, but as you can convert auto to manual OK, it shouldn't matter.
Hi John
The reason I ask is that the manual box still has the manwell harness and I still don't have reverse lights or a speedo as a result, because the manual box harness has a different plug conector and more wires :confused:
Anyway i'm that pissed off that as you move the harness one way to fix a bit. The bit you move is that brittle it just snaps. So i'm just going to replace the lot. So I wondered if i'd need the alternator harness for the manual as well or would the manual box harness just fit into the manual engine harness and everything else be O.K.
