gearbox oil cooler
does anyone know who can supply a larger oil cooler that i can use for the auto box.
I've found someone who will supply a cooler (about £60) for me but the fittings are all BSP threaded.
What I was really after was one I could use that had the same size flow/return parts asthe existing one so I can just find a place to put it and use the same size pipes with jubliee clips.....
any ideas chaps ???
thx
Maybe I am completely missing something here but can't you get adapters which are a bsp thread at one end and a blank for a pipe fitting on the other???
CheerZ,
Andy
Cheers, some of those will solve the problem I guess, thnx
Zach,
Could you please post "How i did this?" answers...with contact details of where you got the stuff from...cos this costs about £250-£300 for a garage to do!!!!
Many thanks
will do mate, no way is it going to cost that much- theres not too much pressure in the gearbox so no high pressure connex are needed and as long as I can find somewhere to mount the new cooler it should all be ok - will have to get a lend of a digi camera sometime though, or get me scanner up and running !
OK how good am I??? biggrin.gif I've done some extra research for you and found http://www.conceptpower.co.uk who claim to be specialists in the field wink.gif
CheerZ,
Andy
Cheers zach..could get posted in the tech sec....looks like could save couple of hundred quid ago...
Regardz
andyduff, cheers - talk about make life easy!
