disc change
Does any one know how to change the disc on the front of my Z 'i`ve never had the disc off before i thought it was two screws holding it on but its not could someone help me. :headvswal
jack up front
remove wheel nuts
remove 2 large nuts on back of calliper i think there 14mm or 17mm carefully slide calliper off disc,the metal pipes from the callipers are weak make sure you hang them up out of the way,as you dont want the brake pipes to snap,iv done it! :headvswal use rubber mallet tap back of disc until loose remove and replace repeat same procedure,making sure everything is torquered,especially the bolts holding the calliper,otherwise warped discs are on the cards
hth greg
