Running Problems
Hello Lads,
A few questions for ya, don't know if anyone can help
1.When I'm starting my auto Zed the power light flashes for a few moments, what does this mean?
2.Recently when its starts its idleing at about 2000rpm, is this connected with the above and how do I solve it?
3.When being driven leisurely its not changing gear untill 4000rpm and then its takes a few moments to kick in. Could it just be the gear box oil needs changing or is the box on the way out?
Would very much appreciate any feedback, cheers GLENN
Power light flashing is telling you the ECU has some stored error codes you need to read.
As for the other problems, take a look at what error code your ECU has and I'm sure that will point you in the right direction.
Cheers 'Take Me To The Pub'. I've booked it into Nissan Next Tuesday to have the ECU read and find out what these problems are. I'll probably have any work that needs doing elsewhere. Thanks for the advice, GLENN
In response to question #2
This could be your AAC valve. It may be sticking, possibly a clean will fix it.
Hi Glenn,
You'd have to be mental to put your Z into Nissans!! there really isn't many of them who know about our Z's. It really is easy to do it yourself, takes 5 mins.
Vijay
